A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
Fuse rating for PS4 Blu-ray drive logic board (BDP-010)
I need to find out the fuse ratings for the 3 fuses (specifically F201) located on the PS4 Blu-ray drive logic board (BDP-010).
Fuse F201 has blown and need to replace it.
Many thanks.
Add a comment
1 Answer
Not sure if it helps, but rather than doing the crazy thing and bridging it, (and without having a clue what ratings they are) I replaced the dead fuse with one I stole from a 3DSXL motherboard. It was tricky to solder as it was slightly too long to meet the solder pads properly but I managed it. Sure enough the PS4 I bought that refused to accept discs into the drive now works perfectly again! I know this is not quite ideal but it sure is safer than just bridging it.
2 Comments:
Hi RGR,
Thanks for your reply.
I ended up bringing up the data sheet for the system motor driver IC (BD7763EFV). The fuse (F201) is connected to the input lines for the sled motor & spindle driver power supply. The spindle driver line can spike up to 3.5A when it starts up so I went with a 4A slow blow fuse and this worked!
by
@angrybeaver Where did you buy the fuse?
by
Add a comment
Add your answer
angrybeaver will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,620
