front passenger door lock actuator
power at unlock button but lock not working all other locks work
Ray, Check if door locks/unlocks off key fob, this means door actuator is working if lock is cycling( if not working off door switch, switch probably faulty).
If no function on this door when using key fob and other doors actuate locks except pass. door, the actuator is probably bad on pass. door. Good luck.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 822
