Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 Questions View all
Screen only displays when I bend my phone, need help asap!
I only noticed recently that the brightness on my screen seemed to be really dim but when I tried to turn up the brightness nothing happened. Found out that my screen displays when I bend my phone and it's not fixing itself not matter what I do. Reset it many times, turned it off and on, need help please!
Add a comment
1 Answer
Most Helpful Answer
I had the same problem. Had to take it to the shop since it was under warranty. It turned out to be a loose connection to the screen. They had to replace pretty much everything on the phone in the process. If I were to do it myself I'd take off the screen and re-attach the ribbon cable.
Score 1
2 Comments:
How much would it cost to get fixed?
by
By a professional? It would probably cost almost as much as getting the screen replaced since the screen itself is not very expensive, but the labour is. I have no idea what it costs in your area. Here it's 100-250€. I'm yousing the M4 as a secondary phone and the screen is shattered so i might replace it myself.
by
Add a comment
Add your answer
MBell101 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 117
