Repair guides and support for your Samsung TV.
1228 Questions View all
2008 model # LNT5271F
2008 Samsung model # LNT5271F
Ghosting, blurring on right side of TV.
Called Samsung, they say this year does not have a tcon box....
Need advice on what part to order and from where. Thanks
Update (10/18/2016)
Hope you can see it!
Comments:
@tweed post an image of what you see with your question. Use this guide Adding images to an existing question for that
by
oldturkey, was this similar symptom to the Samsung junk/failed capacitors on power supply board, that I saw in one of your previous post.
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
It is entirely possible that this is related to failed caps on the power board. You will have to remove the back and take a look at the boards. Check for domed or leaking capacitors. Post some images of your boards with your question so we can see what you see. Use this guide for that. Also it looks to me that there is a T-con board. Again take pictures of all the boards and how they are mounted on the inside of your TV
Score 1
Add a comment
Add your answer
Tweed will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 75
