The Dell XPS M1330 can be identified by its model number: DQPQPD1. The laptop itself has a red outer casing, with a silver keyboard. This model was released on June 26th, 2007.
7 Questions View all
The display flickers and goes down.
I have a Dell Xps M1330, it works great but sometimes it shuts down by itself. When is powering on the display go all white for awhile.
I try powering on several times until the display goes normal again. So I believe its the graphics chip that's causing the problems.
What can I do?
Score 1
1 Comment
My dell is model, inspiron 3521, one nose is coming form the bordo and now is not on
by
Add a comment
Most Helpful Answer
You can check the graphics chip by hooking up to an external monitor. But I believe your problem is a failing hard drive because of the white screen. I have a unit in right now that came in with only a white screen and the new hard drive fixed it. Try booting from your system installation disk and see if it fails, do this with and without the hard drive installed.
Score 1
Add a comment
Shut the machine completely down. Then power it up while holding FN.
It will go through a series of hardware tests.
The only test that you may not see the results is the graphics test. If the card is bad you'll here a series of beeps constantly chiming over and over.
Score 1
Add a comment
Add your answer
Fernando Garcia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 2,372
