The Stream 7 is a compact multi-use tablet produced by Hewlett-Packard and was released in September of 2014.
Why won't my Hp Stream 7 turn on?
I can't turn my tablet on and it's starting to frustrate me >:( any ideas on how to fix this problem?
Add a comment
Hey Brennan!
Sorry to hear about your struggle, but I think I have some ideas that could help!
- Try charging your device. It's most likely dead and a little charge could do the trick
- Try changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
- Water damage is a possibility. If you have soaked your device recently, you may have some luck dissembling it, and soaking the parts in rice or salt; neither will guarantee your device will work when put back together, but success stories have brought devices back from the dead.
Best of luck!
Add a comment
Hey Brennan!
- Try Changing the screen. While opening the device, look for any connections that need to be reconnected or clean.
Best of luck!
Add a comment
Add your answer
Brennan Slater will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 642
