Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
6 plus is dead and its strange!
Iphone 6 plus is dead. Blask screen and no charging signal bu under Itunes is working and charging.
Screen is OK working on other phone, battery also OK - I have smal service and I dont know what should I fix.
It can be U2 on main bord if telefon is working with itunes ???
Please give me some tips what should I check first and next etc ...
Add a comment
Sounds like the backlight driver to me. You need to find someone who can do board level soldering repair.
Add a comment
Like Eric says maybe backlight driver, can you see the screen on when you hold a light up to it? That will tell you if the backlight circuit is to blame. Also check what amps the phone draws through the charge cable.
2 Comments:
I have soldering station and some experiance but here I dont have idea.
No light on screen when connecting to Itines, no sound etc and is charging only by itunes. The old owner said its heppend after battery changing for new one.
I have to make diagnose and maybe fix it with my soldering station and microscope but I dont know what I have to check. Do someone know some weeb side with some tips anout checking steps with broken/ded iphones ??
by
Go on ebay and buy a phone current meter, good tool to have. They cost $8. Iphone should draw right around 1 amp. Any more or any less could indicate a board issue but not sure if it will help your issue. For me, a bad u2 doesn't prevent the screen from coming on. Are you able to restore the phone without error? Also use your microscope to check the lcd connectors and all the chips around for anything bent or missing.
by
Add a comment
Add your answer
Kamil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 87
