4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
LCD, Digitizer, or what?
Awhile back, maybe 2 months ago. I bought a new iPhone se from tmobile, hooked it up, happy as a clam until I got home and immediately water damaged it. It was partially submerged in water for about 3 minutes or so, just the top half where the camera portion is. For the longest time it wouldn't even turn on, I brought it to a guy who basically took it apart and let it sit so I brought it back home, took it as a lost cause. Last might I plug it in and it turns on and looks great home button works, power button works, can't test any other functions because the screen won't respond to my touch at all. THERE IS NO VISIBLE WATER DAMAGE MARKS OR SPOTS OR BLACK SPOTS ANYTHING! The screen looks literally perfect like the day I bought it. So my question is what is the problem? Like I don't understand. I tried to force restart it because I read that on the apple site, and then it started acting weird like the apple logo was just coming on and then going away and then weird green bars like flickered across the screen. Then I turned it off, and back on and now it looks fine. Lol i just would like to know what exactly needs to be replaced???
Please if anyone can help I really don't want to get ripped off :(. Thank you.
Add a comment
changing the display is the best first option. Its pretty cheap and easy to do. The top part of the phone is where the LCD/digitizer connections are, so while you are changing the screen, inspect them for any corrosion. Clean any that you can see with 99% IPA and a toothbrush. Also, make sure to disconnect the battery before you disconnect the screen.
If that doesn't work, then its more than likely damage to the motherboard that requires special tools and skills to fix.
Add a comment
This is more likely the touch connector and touch IC, clean the connectors and the board. If that didn't work, the board is most likely heavily corroded due to higher voltages for the touch circuits.
Add a comment
Add your answer
Haylee Seville will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 91
