Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
80 Questions View all
Why is my battery slowly draining?
The battery and alternator have been checked out and are good. I can drive the truck all day and it stays charged, but I must disconnect the battery cable when I park it overnight or it will be dead in the morning. I have checked wiring on all the harnesses and they look good. Where do I look next? Is this a common problem with Fords?
Score 2
Add a comment
Chosen Solution
Penny, If battery is indeed good, you are experiencing what is known as a parasitic drain of battery. Parasitic drain means something is using power when it should not be, could be a aftermarket alarm/stereo, stuck relay, shorted wire/switch, faulty alternator, etc. I will post a link to show how you can check your vehicle for parasitic draw by pulling fuses and checking amp draw/power with a DVOM. Good luck.
https://www.youtube.com/watch?v=zdIKNnwE...
Score 7
2 Comments:
Some short circuited then some current all time flowing that's battery drain
by
@lpfaff1 Excellent choice for a teaching video , really like using ETCG stuff for simple explanations
by
Add a comment
If alternator is and batter are good checks the starter and starter solenoid they can draw power (parasitic draw )
Add a comment
Add your answer
Penny Peterson will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 161
All Time: 18,084
