Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
PLEASE HELP - iPhone won't charge after screen replacement?!
I have an iPhone which has been charging fine, but the screen was broken..... so I decided to fix it using the guides on this website. After fixing it it worked fine but after it ran out of battery it wouldn't charge!!?? Anyone know how I can fix it, it's not the wire or the powerpoint. PLEASE PLEASE help me, it's bugging me heaps not knowing what happened to it!
Thanks,
Max
Add a comment
1 Answer
Chosen Solution
Did you try reseating the cable that connects the charging port to the motherboard inside the phone? When you replaced the screen, you would have disconnected the charging port cable form the motherboard, so it's possible that it's not fully inserted.
Score 1
3 Comments:
How do i know it is fully inserted?
by
You just need it to click in and it should be somewhat level and not in an angle. Other than that it's probably a accidentally damaged charging port dock connector assembly during repair.
The one crucial question is that did you charge the phone after screen replacement before it went flat? Did that battery percentage go up at all if you did?
by
Ben, I have just done the same thing, my charge is going up slowly like 2-3% every 4 hours, does this mean its not seated properly? or Shall i just get a new battery.
by
Add a comment
Add your answer
Max Lissenden will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,704
