How use analog video output
hello please help me where you could find the following manner from the chamber axis 213: Connection Module - The connection module provides the physical interface to 3relay outputs, two digital inputs, audio in / out, video in / out and the RS -232C serial port.See connection Module, and connects them mcablul aces .or how can I use analog video output of the camera. thank you
Add a comment
1 Answer
Chosen Solution
Hi,
Here is a link to the Connection Module features.
This is what it says about the video out connection:
VIDEO OUT
Via the standard BNC connector, this output allows the AXIS 213 to be connected directly to a traditional CCTV system. Note that to display the image from VIDEO OUT with the correct orientation, the AXIS 213 must be ceiling mounted.
So presumably this means that the module is connected to the camera and the video output can be connected to the video connections of an A/V input of a monitor etc.
http://www.axis.com/files/manuals/axis_2...
Score 2
Add a comment
Add your answer
Mocan Marius will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 84
