Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Screen only backlit after screen, lcd, and battery change.
My Iphone recently stopped showing image, and when I restarted it, it never turned on again. Believing it was the display, I replaced the screen/lcd, but the battery managed to get damaged. I got a new battery, and now it turns on, but its only backlit with a few different colored vertical lines. Thanks for any advice in advance!
Add a comment
1 Answer
Sounds like the LCD you installed is faulty. Vertical lines generally mean that the LCD cable is loose from the LCD or not plugged in to the logic board all the way. Try reinstalling the part and if that doesn't work order another.
1 Comment:
I did some tinkering and the lines disappeared after I made the post. Its still only backlit, and I failed to mention this, but the old screen had the same problem which caused me to reset the phone.
by
Add a comment
Add your answer
Jarred Howe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
