Where can I find a replacement LCD screen
Purchase this tv from a friend the screen was cracked I was wondering where can I find a screen this size 80"
Hi,
On the back of the LCD screen itself, there should be a a manufacturer's name and model number stamped (it might not be Sharp but a specialist screen manufacturer). Search online using this information. You may find, if you are lucky enough to find one, that it may cost as much as a new TV. If you do not wish to go further with fixing this TV, because of this, (as you do not know if there is anything else wrong with the TV, was it powered or turned on when the screen was cracked - if so something else may have happened to it) advertising the components of your TV, e.g. the individual circuit boards etc for sale may help to offset the cost of the purchase of the TV and perhaps a new one.
You could also search online using the make and model number of your TV to see if there are any exactly like yours for sale with another problem e.g. a faulty board etc but that still has an intact screen.
Thank you, no the TV was not powered on, I turned it after it fell into the coffee table and you can see what’s on between the spiderwebbed cracks going across the screen
That should have been a comment not an answer, because I don’t have an answer
I’m looking for a lcd replacement screen for 80” tv
Hi @floyd
The Chosen Solution above applies to most TVs with a broken screen.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 5,454
15 Comments
I have a screen for an 80-inch Sharp TV what is your model number perhaps it's the same maybe we can do business I just want to get rid of it really cheap
by Mike Witt
My sharp tv model number is: LC-80LE632U
by Pierre Tanoe
Hello. I am also looking for a sharp 80 inch screen. But I can also fix mine with the ribbon strips on the bottom.
by Tim
Lookingvfor 80" Sharp Aquos LCD PANEL MODEL LC 80LE642U PLEASE HELP
by Sheritta
looking for 40" sharp aquos lcd panel model LC-40LE265M.. MY TV LCD PANEL BROKEN..
by rolin junsay
Show 10 more comments
