Is it my Catalytic convertor
I ran out of gas (one time) and my car would not run after that. The fuel filter has been replaced, fuel pump replaced, spark plugs replaced, and gas tank removed and cleaned. It is still not running right and the check engine light is blinking. I filled the tank and put fuel injector cleaner in it. Is it the catalytic convertor.? If so can it be cleaned or must it be replaced? Could it be something else?
Score 1
1 Comment
Does it smell like rotten eggs? Does it run hot all the time. If so, you should have a good mechanic check it out soon. If you wait to long it may damage the engine.
by
Add a comment
1 Answer
Chosen Solution
Ryan, Have a good technician scan/check your vehicle for trouble codes as a first step in trouble shooting the engines performance problem. A good technician can run test to see whether converter is bad rather then throwing expensive parts and labor at it. There are lots of things that could cause engine to run bad , vacuum leaks, plugged EGR,faulty injectors, faulty coil, etc., have it scanned.
Score 1
Add a comment
Add your answer
ryan will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 50
