Why is my shift gear lever stuck in park?
I have Ford Escape 2011 model. Suddenly, I noticed that the gear lever is stuck in park position and would't shift from there unless I depress the override button. I have the feeling that it may not be the shift solenoid because an auto electrician once used a jumper cable between the switch under the dash board/brake pedal and it (solenoid) actuated very well (though I told him to disconnect the jumber cable). Atimes the lever works well especially in the mornings but not always.
My email address is anyadikejohnson@yahoo.com
Update (11/19/2016)
Finally, I bought the brake light switch and replaced the old one but the gear lever is still stuck in park position when I match the brake pedal. It did not fix the problem.
Note the the brake light do come on whenever I match the brake pedal.
Is there any further solution to this?
Correction to my earlier submitted question
"I have the feeling that it may not be the shift solenoid because an auto electrician once used a jumper cable between the switch under the dash board/brake pedal and the solenoid and it (solenoid) actuated very well (though I told him to disconnect the jumber cable).
by Johnson Anyadike
Note that the brake lights come on when the brake pedal is depressed.
by Johnson Anyadike
