T800 Battery decreasing while turned off and on charge?
Hi
I have a Samsung T800 tablet and which is having some serious trouble charging. It originally had a damaged charging port which was replaced and since then whenever its plugged in to charge the battery keeps draining even while switched off. This also happens with a new battery.
Any ideas?
Thanks in advance
3 Comments
@hortman did it ever work properly after you repalced the charging port? Have you verified that the replacement is properly installed?
by
It did work here for me when i changed it. port does seem to work properly, it shows the battery symbol when plugged in and has the little bubbles. Should I try another?
by
So from what you are saying that it is indicating that it is charging but it is not? I would double check the connector and the connection.
by
Add a comment
1 Answer
Chosen Solution
@hortman if your connector and the connections are properly installed, follow the troubleshooting suggested by Samsung.
Score 1
1 Comment:
Thanks oldturkey03 thats exactly what I need, sorry its taken so long to reply, been busy with other repairs
by
Add a comment
Add your answer
Hortman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 94
