Model A1320 / 8 or 16 GB capacity
156 Questions View all
Question Closed
adhesive on replacement glass for 5th gen nano
purchased replacement glass from you. the replacement glass has adhesive strip across entire back of glass. Is this right or should it be be removed? with the glue all over the glass it does not seem to be transparent. Seems like adhesive should only be around perimeter/edge of glass.Does not seem right to have adhesive in direct contact with display surface. How do I remove it as there are no pictures of this step in your instructions.
Robert
Add a comment
1 Answer
Peel off the three layers of paper/adhesive from the center of the glass. Why is there three layers I do not know. There is just one layer of paper covering the adhesive on the edges. Peel and stick.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,172
