2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
MacBook Pro 15" (late 2013) logic board repair resistor
I have slight water damage to a Macbook Pro 15" late 2013. I have run and tested all components and have found (3) shorted resistors. Everything else seems to have the correct values. They are the large square ones near the top of the board near the display, labeled R36 338 V69. I have not been able to locate any suppliers with these chips. Would anybody know a good place to acquire these components.
1 Comment
Those are inductors not resistors.
by
Add a comment
1 Answer
Chosen Solution
It's very difficult to troubleshoot a complex circuit board without a schematic. They are available if you look around. Louis Rossmann (https://www.youtube.com/channel/UCl2mFZo...) has a great channel for repairing MacBooks.
When it comes to water damage, always start by looking at the areas that are corroded and try to identify bad components. What often happens is that main power rails get shorted to ground due to the liquid. This can cause local or extensive damage. Capacitors are susceptible to damage and can short a power rail. However, sometimes the problem is within the power supply chips themselves (LDO).
Get the schematics, give it a try...
Score 1
Add a comment
Add your answer
Sync will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 600
