HD action camera released October 5, 2014.
Camera trigger and Wifi button not functioning
Hello
I changed the stock lens with a non distorted version, in the process I accidently pulled one of the 2 side connectors (top gold) loose when separating the body from the components. I believe this is responsible for the Wifi and trigger functions.
The camera turns on with LCD display working with no issue.
Can you repair?
Regards
Charles Roeder
Add a comment
1 Answer
Hi Charles
Yes you can repair it pretty easily.
You need to almost completely desemble the camera tho. So make sure you have a good quality screw driver.
What you want to do is make sure that you connect the gold cable and power to the motherboard before putting it all back together again. You might need a pretty good tweezer as well to help.
Good luck.
Geoff
Add a comment
Add your answer
Charles Roeder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 36
All Time: 152
