Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 Questions View all
Are Ipad Air 2 wifi version speakers compatible with the cell version?
Are speakers in the store that are available for the Ipad Air 2 Wifi version compatible with the cellular version as well? Common sense says they would be but I wanted to check to make sure before I tore down my iPad
Add a comment
1 Answer
Most Helpful Answer
The speakers should be the same, as there is no reason why Apple should make different models of the speakers for the cell and wifi iPads. If you can, compare pictures/serial numbers and see if you spot any differences, but I can say for sure that they shouldn't be any different.
Score 3
2 Comments:
Ok thanks. I was just making sure and I wouldn't think they would change anything
by
*usually* iPad parts don't change between 4G and wifi. The only things I know of for sure are the obvious: the rear case, antennas and main board. Other than that, they are all interchangeable.
by
Add a comment
Add your answer
Tyler Vaught will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 38
