How to open up linksys AC1200
I have a linksys WiFi Router AC1200 and want to open it up
to attach a pole mounting clamp
to the bottom so I can mount it on a speaker pole
There is no screws...
Score
0
Hi, Not certain about your model router, but with some there are screws under the foot pads and also if the router has a label on the bottom, there might also be one hidden under it (recessed below the case). Even with the screws out you sometimes have to pry the seam open between the top and bottom halves of the case to disengage the snap clips that hold it together. I find if you haven't got a proper 'pry' tool that using the corner edge of an old credit card works too.
by jayeff
