honda accord 2000 air conditioning
air conditioning stopped working on Honda accord 2000,how come it still blows hot air with air condioner turned off and heat nob turned to lowest setting
gsh. Check that the inline heater hose control valve is working properly, the valve restricts coolant flow when A/C is turned on and set to cold setting.There should be a cable connected to the arm on valve to open and close the valve have somebody switch your temp knob and observe the lever is working properly. There can be many reasons for the A/C not to function properly, Low refrigerant, plugged system,
faulty compressor, Condenser plugged externally /internally,etc. Best to have a qualified tech. have a look, diagnose and estimate repair.
Check the trouble shooting links below. You can also do a google search yourself, lots of info. out there on your problem.Good luck.
http://www.aa1car.com/library/ac_no_cool...
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 5,739
