error code on the panel
an error code F0 shows on it
Update (09/10/2016)
thanks. my model is Kenmore range elite C 970
@camartin F0 in general is the error code for a failed thermistor control. Not exactly knowing which model your Range is try a reset which may be for a different model. This should clear the error codes:
Power off the unit, wait 5 minutes then restore the power.
Press the broil and bake keys simultaneously and "SF" will be displayed.
Press "Hr. Down" and "Minute Down" keys simultaneously for 3 seconds, then the time of day will be displayed.
Press "Temp Up" and "Minute Up." The control panel will display the following:
Go blank briefly
Display all segments briefly
Display "LOC REF" briefly
Display all segments again for 30 seconds
Display "LOC REF"
Acknowledge the "LOC REF" by pressing the "Hour Down" and "Minute Up."
Test control pads. Oven should now function.
from here. this could be as bad as a failed circuit board to as simple as a corroded plug at the oven sensors.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 20
All Time: 2,306
