Why is my sound choppy?
My tablet doesn't have any sound, but if it does it is very choppy!! Also, the sound works with the headphones! However, I don't think that it was water damaged!
Louanna, if you are sure the settings are not on mute, try rebooting a couple times and see if that fixes volume. If no luck you can try a hard/factory reset, but you will loose all data on the tablet. If the reset still does not correct issue, the speaker/board is probably faulty and may require a technician to repair.
In case you decide to do a factory/default reset , i will post links to tell how to do reset and back up your data before reset.
Check the attached links,instruction and guides, Good luck .
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 174
