iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Questions View all
Only bootable in safe mode,damaged vsync cable
This iMac have a damaged vsync cable.
it can only boot up with safe mode, without safe mode it will always stuck at the apple logo after the chime or load up a cursor then became the beach ball. If it idle long enough in this state, the display will go to sleep.
When in safe mode, I can't run cinebench to test the gpu in safe mode. If I try to browse the web, Safari will flicker non stop, the video is just black colour. If I connect a external monitor and drag safari to the external display, I can view a flickering image of the video.
If I use safari in recovery mode, it flicker a lot lesser but stuck with beach ball and flickering stop.
Is this more like gpu issues or I just need to replace the vsync cable?
Add a comment
1 Answer
Most Helpful Answer
You'll need to start off replacing the Vsync cable.
Your symptoms are not at a point which tells us enough.
I would also recommend you try either booting up on an external drive or try running in Target Mode connected to a second Mac to make sure your drive is OK.
Score 2
3 Comments:
The drive is definitely working, tested with known working unit. Currently using a SSD. Just curious that can the vsync cable cause it to not bootable. Will change the vsync cable once I receive it
by
I believe you that you think the drive its self is good. Please still do the tests as it is also testing the system.
by
@danj the vsync cable is working, after i reformat the SSD and intsall yosemite, i was able to watch youtube video. However, still wasn't able to boot up normally. I had remove all the ram and test it one by one. Any suggestion on how to proceed from here?
by
Add a comment
Add your answer
cheelam1220 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 125
