2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
No light on MagSafe LED & can't turn on my MacBook
Hi all,
My macbook 2009 suddenly will not turn on one day.
  • No response at all when pressing power button.
  • Plugged in MagSafe power adapter in doesn't show any light on LED (green or amber)
I went to Apple Store they suggested it's the issue with MagSafe/DC-In board since they tried with a new power adapter and still there is no light on the MagSafe LED.
So I bought a new MagSafe/DC-In board, changed it out, but still dead. Tried SMC reset that didn't help.
What should i look into next? Would it be just dead battery or something else?
Any advise would be great!
Thanks.
Add a comment
1 Answer
Chosen Solution
Tough one to diagnose over the internet. There are no clues.
Try this. disconnect the battery (check it for swelling while your at it). Dis connect the mag-safe adapter. Press and hold the power button for 15 seconds. Reconnect, try starting and tell us if you get anything.
Score 2
2 Comments:
I do not have the Y1 screwdriver. I tried to do your suggestion but with only disconnecting the battery cable. Nothing happen, stays dead. I will try to get a Y1 and see if battery is swelling.
by
You don't need the Y screwdriver. To disconnect the battery yo don't need to pull the battery from the laptop. Just disconnect the cable.
by
Add a comment
Add your answer
Karaz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 167
