Repair guides and support for your LG TV.
1340 Questions View all
My remote is not responding to TV, changed batteries
My remote is not responding correctly to TV. When you press the remote to Channel or volume it automatically goes to the highest volume, and the channel just goes up continually without stopping
4 Comments
linda241067 I am a bit confused by the interactions on here. Just to clarify, your TV "goes to the highest volume, and the channel just goes up" regardless of which remote you use? The remote from your TV does work on other TV's. The remotes from another TV do not work on your TV (same issue). Am I correct with this?
by
Yes, I have two lg tv. My remote was not working with my tv, the volume just went up, as did the channel. I got the other remote and it is working fine and the remote that was not working on my tv works the other to fine.
by
Only power button is working not the other buttons pointer is not showing plzzz tell me how to slve it….
by
Hi
Can anyone help me with lg magic remote?I have problem when i tru to set my magic remote as universal remote for set box tv.When i go to device menagement or inputs i can see that my box tv is connected but i cant syns my magic remote with tv box.Same hapends with sony console.
Sorry for my bad English
by
Add a comment
Chosen Solution
Linda, Reprogram your remote to your TV, you can google search your remote for instruction if need be. If no luck, pick your self up a good universal remote, read packaging to be sure it is compatible with your device.
"I hope this helped you out, if so let me know by pressing the helpful button.
Score 1
Add a comment
Most Helpful Answer
Hi,
Use a digital camera or the camera app of a mobile phone to test your remote control.
To do this just point the remote at the camera (or phone), press, in your case, the volume or channel button and check if you if can "see" a flash at the front end of the remote when looking at the camera (or phone) display. The flash should cease when you release the button. If it doesn't then the button may be sticking and needs to be cleaned. Try another button which works OK to see the difference.
Here is a link that shows how to clean the remote control buttons.
https://www.youtube.com/watch?v=gVr8eLW0...
Hopefully this is of some help.
Score 2
13 Comments:
Tried this and light flashes. I have tried the remote on another to and it works perfectly. I use a different remote and the same things happens. Could it me the tv
by
Could the tv be faulty, as some times it works and some times it doesnt
by
Hi @linda241067
What is the exact model number of your TV?
by
32LD.350 TA is the model number
by
Hi,
Does the same thing occur when you use the CH+ and Ch- or the Vol+ and Vol- buttons on the TV itself?
If not it points to a problem with the IR (infra red) circuitry in the TV.
Are you having any problems with any of the other "function" buttons at all, not the channel number buttons e.g. subtitles or programme guide, if you press a button and the function appears and then disappears - like you have pressed the button twice but you only pressed it once. Again if this test doesn't function properly it points to an IR problem.
You could try a "reset" and see if that works. Unplug the TV from the power outlet, then press and hold the Power button on the TV for about 30 seconds, then release the button. Reconnect the power and switch on the TV and see if there is any change.
by
Show 8 more comments
Add a comment
Add your answer
linda241067 will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 140
All Time: 51,811
