Dryer is overheating despite replacing heating element & thermostats
My Maytag MEDC300XW0 dryer is hot. So, since I've torn it apart before and replaced stuff, I did the same a few days ago and found that the thermal cut off was not working and the heating element coils looked shot.
So, I ordered the parts and put them on today and turned it on. Heats up just fine but seems to be really hot at the top of the heat box ( too hot to touch after just a couple minutes). Just wondering if there is something I'm missing or that may be causing this problem.
The vent is blowing out hot air and the lint system has been thoroughly cleaned.
4 Comments
Same for me! I’ve replaced thermostat, high limit and the heat coils. Even in “Air Only” mode, the coils heat up? What else is left?!?
by Pat D’Anna
Pat, did you ever solve this issue? I’m having the same problem of the dryer calling for heat even in “air only.”
by Keith Miller
Your heating element is grounded! To check this use a multimeter to test for continuity by placing one probe on one of the terminals to the element, and place the other probe on the casing of the element. If there is continuity then your element is grounded and needs to be replaced.
by ilovekyleeann
Hi Pat,
Same problem here. Did you find a solution?
by Ryley Nihart 2024 recruiting
