A line of child-friendly tablets by Fuhu.
Power chord doesn't fit (may have been bent) and doesn't charge.
Can no longer fit the power chord into the charging portal. The chord has a purple mark on it like it over heated. The dreamtab doesn't charge anymore. Could the charging port be replaced?
Add a comment
Most Helpful Answer
Most likely you need a new charger if the cord is damaged. Also inspect the socket on your tablet to see if one of the pins is bent or damaged before trying the new charger, hopefully its just the charger.
Here's a link to a new unit: nabi 2: Charger Replacement
Score 1
Add a comment
The charging port can be replaced but requires a new board snd the ability to solder. You can find a new board on ebay for under $300.
Score -2
1 Comment:
Sherry - Sometimes the simple answer is the answer.
by
Add a comment
Add your answer
dreemquilter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 92
