Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
Headphone jack doesn't work
Hello, my headphone jack doesn't work, if I connect headphones, it's the same as I don't connect anything.
I tried to replace the charging dock (which is with headphone jack), no success.
any idea?
Add a comment
I assume you've tried another set of headphones to ensure that that is not the problem. You might also check the obvious culprits such as that the volume is turned up for the particular source you are using in the phone's mixer, and that Bluetooth has been temporarily turned off to ensure that the phone doesn't think it's supposed to be talking over Bluetooth rather than over the headphone jack. Other than that it's likely the jack has failed and if so there's no choice other than getting the phone repaired
2 Comments:
I will try it, if that doesn't work i will even try one more time to replace the dock with a new different dock and post back. iPhone isnt useful without music. thank you :)
by
Hello. Much time passed but I eventually received the charging dock.
I did what said. I put volume on the maximum, bluetooth off, no sound via aux. inly speakers.
So I replaced the charging dock. The phone charges well, but still no sound via aux. if i connect many headphones or just aux cables, the phone keep playing by speakers like it doesn't recognize the aux port.
by
Add a comment
i have the same issue !
ive changed the dock three times and nothing. i get a the same horrible crackling from one headphone bud, i have tried different headphone and nothing.
anyone have a solution ? new logic board ? a replacement part i could try attaching the headphone cable to the logic board ?? any suggestion please
Add a comment
You just need to buy a short 3.5 mm mini jack male to male cable cord that will connect the headphones with the adapter.
Add a comment
Add your answer
Einly will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 224
