Sleep sensor not working
Hi.
After changing thermal paste on my systems CPU. I screwed it all together and now my sleep sensor is not working if i close lid, display stay on and doesn't turn off.
I must push the power button for 2 sec to sleep .. and if i close lid when charging the green battery test are very weak.
Photo battery light when is closed lid and opened.
Thanks for reply
3 Comments
Why did you apply new thermal paste on your CPU? Who's product did you use? And, did you fully remove the old paste?
As for the battery tester there is current leakage which is why the tester is lighting up slightly. Often thats a sign of liquid damage.
by DanJ
Because i had problem with overheating . but why is lighting up slightly only if is lid closed ? .. and if i turn off macbook, the battery led is working fine in closed and opened lid .
by Kristian Brinda
Current leakage here is likely some staining on the main logic board from the cleaner you used to remove the old thermal paste. This can also explain your sleep issue as well.
by DanJ
