Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Screen Flickering, after display change
I have replaced my MacBook retina Display with a brand new one, but then the screen flickers with colors and when I move the mouse pad it stops and even if I put it on safe mode the display works very fine. What could be the problem and how can I solve it.
1 Comment:
Can you explain why you replaced your display. And are you sure you got the correct one for your system? Give us the P/N you put in so we can check.
by
Add a comment
1 Answer
It appears as if you didn't connect the display wire properly to ur motherboard.
If that is not the case u could try making a time machine back up and reinstalling OS X from recovery
4 Comments:
@riptide - Talha, Did you see the clue here? It is AOK running is Safe Mode. That would imply the cable was firmly connected. So whats different between Normal & Safe modes?
by
@danj yes you are right I misread his post.
So in safe mode some unnecessary kexts are not loaded. That could be the problem. So either boot without kernel cache or reinstall OS X like I said :)
by
Thats one possibility, but what is the clue here it still could be a hardware issue? Reread the OP's Q and what I asked.
by
@manaaf can you tell us why did you replace the display? was it a problem? and if so what was it?
by
Add a comment
Add your answer
Naf98 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 130
