iPhone 6 will only recognized some OEM chargers?(Video with the issue)
Video here https://youtu.be/RJ3zIH5dF2M
I have ran into this problem a couple times before where an Iphone 6 will only read some chargers. There don't seem to be any correlation between when it will charge are not. I'm using ONLY apple parts and on the last test is when I plug it into a computer. I have switch around the cables between the computer and adapters and the result was constant with 12 or more cables cables. I've replaced the charging port and the issue continues the same chargers work or don't work as the first test with the OEM port. The chargers have been used to charge 25+ devices so its not just the one testing devices working with all chargers.
No water damage.
Is any one else having this issue?
I've been hearing this issue from multiple iPhone 6 users. I have come to the conclusion that it is some board issue on the charging circuit where it can not properly identify lightning cables because of some chip being damaged. Not really sure what it is, hopefully someone will know here.
by Ben
