Stickies application will not open.
When I click on the stickies icon in the doc or in the applications folder no stickies will appear. I get the stickies bar across the top but no stickies.
Sandy
Sandy
On the menu bar at the top navigate to Window and confirm that there are any active stickies. There should be a list of all open stickies there, click one to pull it to the front. If there are no stickies listed, then all Stickies have been closed. Make a new sticky by going File>New (+N).
if you see the menu bar change, and the throbber in the the Dock. Also check under Apple icon->Force Quit if it's frozen it will be noted.
• To close this note, click the close button.
• To collapse this note, double click the title bar.
• Your current notes appear when you open Stickies
If you have no new or current notes there's nothing to show.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Thank you so much. You rock!
I had a similar issue with my computer showing the Stickies app being open, yet the Stickies were not visible.
Hope this helps at least one person.
guys real problem solver for disappeared stickies, check this link out , https://www.howtoisolve.com/sticky-notes...
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 64
All Time: 13,311
