Repair guides and support for your Samsung TV.
What is causing these horizontal lines
I have a Samsung UE40D5520 Led TV
It has horizontal lines going across the top of the screen.
The lines are always present on tv video and pc.
The lines are on top of the test screen.
Adjusting the screen up or down the lines dont move.
Can you tell me what is causing this.
line fault
[IMG]http://i66.tinypic.com/25j84yr.jpg[/IMG]
[IMG]http://i63.tinypic.com/15xaia0.jpg[/IMG]
Score 6
8 Comments
I have added some pics. Hopefully you can view them . If not let me know.
by
samsung smart TV 66 inches has a line going down from my right side not to dark I could still see but not comfortable when I paid 600$ and after 6 months it happen
by
i have aUN55MU650D
I have line going through the bottom of TV. When you bring up apps its almost right there. Any advice on what to do or how to fix it?
by
[image|2167944]
can some please help , when i switch on tv a white horizontal line appears on the screen , tv switches of and then on again constantly with the same white line
samsung 55inch uhd tv model UA55KU7350K
by
2 lines going across the too of the tv?
by
Show 3 more comments
Add a comment
Most Helpful Answer
@mynameisstu horizontal lines are most often caused by a bad panel (failed GATE drivers or failed TAB). Not much a DIY'er can repair on that. Post some images of what your screen looks like so we can see what you see.
Score 3
6 Comments:
Hi. I have the same problem I have some pictures but i can`t seem to put them on this page.
by
@sidc what make and model is your TV and what do you see on your screen?
by
Hi we have a vertical and horizontal line on our Samsung 65" led smart tv please help it's only 20 days old!!! Many thanks
by
@cmcn01 if it is only 20 days old I would get this checked under warrantee. If that is going to problem than we can try to assist you further, but we would need your TV's model number etc.
by
Hi i need your help guys i have a Philips 32 Smart TV it has horizontal lines, first time it show only 2-3lines but now there are tons of them. Pls i need help. Its no longer under warranty. Service center cant do anything about it tho
by
Show 1 more comment
Add a comment
Hi @ Steven Hernandez,
If the TV is only 6 months old from new, consult the warranty documentation that came with the TV, about how to get a manufacturer’s warranty repair or replacement
Score 1
Add a comment
Hi.
It's the connector. Simply.
But yea, maybe its the logic board that is broken. And Samsung is known for making tv's that break after a year or two, so your best bet, is to go buy a new one.
Well, hope it didn't make your day bad. But still, have a nice day cheers :)
4 Comments:
Seriously, ilatitao? It's blah blah. Simply. But it may be this. Or maybe it's that. Oh wait... It's probably this. For Christ's sake, why even reply? Here's a proper answer. 9/10 times, it's a faulty panel. Those do not get repaired. You have a 1/10 chance of it being a loose connection. It's worth trying, but don't get your hopes up. Vertical or horizontal lines of death are called that for a reason. Really sorry bout your luck. I do recommend purchasing an LG or Magnavox over a Vizio, Samsung or Sony, and whatever you do, don't buy an Element or the really cheap Walmart off-brands. You may as well go to the ATM, withdraw $500 and give it to the guy at the overpass that's flying a kite for beer money.
by
Bad connection at bottom on panel. One of the two ribbon connectors isn't home properly
by
What would make a loose connection? My tv hasn't been moved for 3 years. Do the ribbon connectors just fall out?
by
@paynecity a bit late but just for clarification. Most common reason is heat/humidity creates corrosion as well as loosens the tabs. It all depends on make and model; where the driver boards are located and other external issues.
by
Add a comment
MY PROBLEM DESCRIPTION: a faint (watermark quality) multi-colored ‘banner’ across entire screen of my 65” SAMSUNG TV, approx 6” above bottom of screen, and 6” high, made up of multiple lines of what appeared as possibly highly blurred text or interference signals of some sort. this problem suddenly appeared following a storm related power outage.
MY SOLUTION: after much research, checking all connections to TV, doing the video diagnostic test in ‘setup’, and actually considering replacing this 3 year old TV, …i simply switched off the main power (basically pulled the plug), and switched it back on after about 30 seconds. Problem solved /perfect picture again!
3 Comments:
i have horizontal llines with my 43" smart tv what solves the problem
by
ua-55f9000 samsung smart tv
multiple horizontal lines showing in the panel.
how to sol ve this problem?
thanks
by
Just started today, a band of tiny lines at the top of the screen fading out the picture. Did picture diagnostic, troubleshooting mode, unplugged and replugged, nothing worked. What to do?
32" Samsung Smart TV
by
Add a comment
Add your answer
Stuart Black will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 29
All Time: 113,001
