Repair guides and support for cars manufactured by the Nissan Motor Company Ltd.
688 Questions View all
My 1999 nissan quest van stall and wont start
Came to a stop light It die and don't start It turns over It got gas in it someone said there's no spark it was fuel pump and another said it was timing I don't smell gas in the motor area .
2 Comments
jewel king besides all those things you were told, what have you checked? Checked for spark?
by
It cranks but will not start
by
Add a comment
Chosen Solution
Your van needs 3 things to run gas spark and air. first listen for the fuel pump. turn on the key but don't crank the motor. do you hear a hum from the rear of the van .If not you need to find out why it could be a bad pump or just a fuse or relay. If you can hear a hum this is the fuel pump and that's good. Next check the pressure on the fuel rail . If there's no pressure you may be looking at a fuel filter being plugged. or a faulty pressure regulator. If you have good pressure check for codes . Are there any codes in the on-board computer. If there are codes they will need to be addressed . If there's no codes check the air breather on occasion the air breather can become so clogged it wont run. You should also check for spark by pulling a plug and looking to see if there is a spark present . you wont always get a code for no spark but you usually do. If you dont find joy from any of these suggestions there one more thing to check . The engine temperature sensor . If for some reason it throws a temp thats not consistant with the normal operating temperature the engine will not run. Hope something in this will help
Score 2
Add a comment
My nisson quest van will run for about five -six miles then it turns off and will not start any more until it cools off, I put in a new fuel pump but it keep on doing the same thing
1 Comment:
Im not a mechanic but when mine did tjat it was the cam sensor...and on the 1999 Quest the cam sensor in build into the distributor.
by
Add a comment
I have not seen this answer on here yet! I have a 1999 Nissan Quest also. All of the sudden my van wont start….it tries to chug chug chug but no vrooom. I checked all of the fuses and relays …I replaced the crank sensor. I replaced the cam sensor. And because the cam sensor is built into the distributer I replaced that also. Then I replaced the fuel filter. I checked all of the wires…This was not in the Haynes repair manual…but I found the little owners manual that came with the van. The 1999 Nissan Quest has an INERTIA FUEL SHUT OFF SWITCH. I HAD NO IDEA. APPARENTLY IT IS A SAFETY FEATURE. IF YOU GET INTO AN ACCIDENT, OR EVEN HIT A CURB OR POT HOLE THIS INERTIA SWITCH AUTOMATICALLY SHUTS OFF YOUR FUEL FLOW! ALL YOU HAVE TO DO TO RESET IT IS TURN YOUR KEY OFF PUSH DOWN ON THE RED BUTTON LOCATED LEFT OF YOUR EMERGENCY BRAKE THEN TURN THE KEY BACK ON FOR A FEW SECONDS, TURN IT OFF AGAIN. THEN IF YOU DONT SMELL OR SEE ANY GAS UNDER YOUR VAN LEAKING….GO AHEAD AND START YOUR VAN! Ill try to post a photo in a minute.
Add a comment
Add your answer
jewel king will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,928
