The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Cancel function is not working
I ran a load on the Jeans cycle last night with the automatic time of 54 minutes. I paused the cycle at 26 minutes. Then I pushed Cancel and the cycle reset back to the original 54 minutes and would never clear off after pushing Cancel many times.
I left the door open so it wouldn't run and today all looked great. No lights or indicators on. I started a Touchup load on Low to test and after 2 minutes Paused and then Cancelled. It all looked good and then all of a sudden the dryer set itself for the Jeans cycle. I tried to Cancel again and it immediately set itself to the Jeans setting. It lets me change to other settings but does not cancel all together.
1 Comment
Thank you! I will try that. When I got up this morning there were no lights or indicators on and I dried a load on Casual and it ran fine.
by
Add a comment
1 Answer
Most Helpful Answer
momoffab4 try to reset it by unplugging in for a while. Not just turning it off but physically unplugging it. If that does not yield any result you could try to press and hold in the select and start/pause buttons together until def appears in the window. That will reset the machine to the factory settings.
Score 1
Add a comment
Add your answer
momoffab4 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 927
