Aftermarket digitizer makes falsereads
About a year ago i replaced my entire LCD and apparently it was a garbage screen as the glass separated from the frame on the upper half of the device, at times the digitizer would go insane and make false reads on the lower half of the screen but when i pushed the top half it would go back to normal.
Yesterday i simply glued back the screen to the frame successfully but now the false reads are even worse and i have come to find out that the only way to get this problem to stop for a while is to push the lower part of the screen slowly by the edges.
The frame has a bit of wiggle room the right side but i figured that wouldn't make a difference as the LCD and digitizer is attached to the glass not the frame and wont effect the pressure between them as the pressure seems to be the problem here.
Its also worth to note that i small glass less part in the left lower corner that reveals just a glimpse of the LCD
I'm looking for help to diagnose this problem as im currently out of ideas so feel free to ask questions about the condition and what happens to the phone when you do X.
