Fix Your Stuff
Right to Repair
Parts & Tools
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
5064 Questions View all
Device does't charge but doesn't drain
I have an iPhone that I have replaced the battery in twice and each time when the phone is plugged in it doesn't drain the battery but it doesn't charge either. I have tried a variety of different chargers and they all do the same thing.
Any help would be appreciated!
Thank You!
Score 1
Comments:
Sounds like a charging ic chip issue. Have you taken the phone to a repair shop that does board level repairs to diagnose this issue?
But if the battery % is just stuck then that is probably the battery guage chip which if I remember correctly sits on the logic board near the battery connector.
But both of these things aren't easily user replaceable. Better to get someone that is experienced in board level phone repairs to do it so you don't risk damaging the board if you do it yourself.
by
Add a comment
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
1 Answer
Chosen Solution
More than likely Tristar chip/U2 IC issue, replace and see if it works.
Requires board level microsoldering. :-)
Score 1
Add a comment
Add your answer
hriebl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 51
