Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Why would there be no display?! blank screen ...
I just replaced my third iphone 6 plus screen using the excellent step-by-tep guuide found on this site. I did a display test prior to securing the "front display cable assembly plate" ( the small one in the top right of the phone) the screen came on, it was beautiful. i then powered off the phone, propped up screen and began to screw in plate. long story short, the display is blank now. The phone will not power up or display a thing!!
I am at a loss. nothing was done between powering down following the display test and the final screw being put in the plate .....
Add a comment
1 Answer
Most Helpful Answer
hold power and home for 30 seconds, see if it boots back up.
If it doesn't, plug it into your computer to see if the computer sees it. If it does, then look very carefully at the screen to see if the screen is on, just very dim.
Report back with results.
Score 1
Add a comment
Add your answer
Kelsey Haughee will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 64
