Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1234 Questions View all
No screen, no vibration, no soud but recognize by iTunes
Hi i have problem, my iPhone 5C dropped on the ground and display was almost functioning but only when I pushed on him
So i disassembled iPhone and try reconnect display cables.
Now when is iPhone plugging into PC not vibrate and screen is black, but is recognized by iTunes.
Thanks for any advice.
Add a comment
1 Answer
Most Helpful Answer
Chances are its a broken display. This is the simplest, easiest and cheapest thing to try first. Replace the display and then restore it in itunes.
There are some much less likely things it could be, but starting off with the display is by far the easiest thing to try.
Score 1
4 Comments:
HomeButton also not working , may be a problem under charging port with speaker ?
by
The speaker would have nothing to do with it.
Replace the display and report back.
by
and isopropyl alcohol to clean the contacts?
by
Always 99% IPA to clean. Clean every contact you can, except the battery connector.
by
Add a comment
Add your answer
vasekopacalek2 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 167
