The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
497 Questions View all
Washer not draining, after third load, tried rerunning cycyle same res
My 110 series Kenmore apt sized washer does several Loads and then on the last load it doesn't fully drain and there's water still left in the bottom, rear end cycle and still won't drain now I smell a burning smell should I try belt dressing?
Add a comment
1 Answer
Chosen Solution
The burning smell require examination.
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Score 2
Add a comment
Add your answer
Sheila Weatherspoon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 238
