Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Erased both partitions on my systems HD by mistake
Hi every one!
I erased both partitions on my drive using disc utilities by mistake. I guess I erased the hidden recovery one also so now can do anything and have no OS that came with it.
What should i do?
Add a comment
1 Answer
Chosen Solution
There are a few ways you can still recover things here.
First, Do you have something on the drive which you need to recover? If you do, you'll need to find a friend with a Mac that you can connect your Mac to using Target Mode (see below on how), then using a file recovery program try to recover your files. Whats important here is if you try to restore your OS before salvaging your files there is a likelihood you'll damage some of them.
OK, let say you've got a good backup or don't care whats on the system lets move on ...
If you have a means to connect to the internet (Ethernet connection) and your systems firmware has Internet recovery services you should be able to recover that way. Here's a good writeup that explains things: How to Re-Install OS X with Internet Recovery on a Mac. Beware! this process will take quite awhile. Start it up and spend the day or night doing something come back in 8 or so hours things should be ready for you to continue. Make sure your system is plugged in as well.
OK, you don't have a good internet connection (very slow) or none at all. Then you'll need to find a friend with a Mac which you can either connect your system to, or you can create a USB thumb drive recovery disk (16 GB or larger). You'll need to connect your system to your friends via a FireWire or Thunderbolt cable in Target Mode. Here's a good write-up: How to Boot a Mac in Target Disk Mode Basically, your system becomes an external drive to your friends Mac allowing you to install the OS onto it.
If you can't use Target Mode then you'll need to setup a USB thumb drive as a bootable drive and then copy the OS installer to it. Here's the steps for that: How to Create an OS-X El Capitan Boot Installer USB Flash Drive
Score 3
2 Comments:
Thank you. i dont need back up. I was trying to erase everything so i can sell it but erase both hard drives. I have another same machine in the house so if there is easy way to maybe copy os and transfer it to another one
by
Well ... You'll need to use Target Mode to connect the two systems. But you'll in fact run the OS installer to install the OS onto your system via the other system. Again, your system is like an external HD when in Target Mode. You'll follow the steps outlined here: How to Install Mac OS X Lion Using Target Disk Mode. Don't worry about the version of OS all of them follow the same method.
by
Add a comment
Add your answer
Harley Davidson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 122
