Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Mixed up the screws
I was doing my own repair and was doing well. Until I turned on the hairdryer. Not my best decision. But now I don't know which screw is which. I have a ruler and can decipher larger sizes but of course 0.1 mm is not easy to spot with a naked eye. Does anyone have a guide with pictures of the screws? I know of one that says what sizes go where but that doesn't tell me which ones are those sizes.
Oh and I'm missing like 4, I'm guessing every screw is essential..?
Score 2
Add a comment
1 Answer
Sure
here is a really good picture guide with all possible information needed for you
iPhone 6 Screen Replacement
1 Comment:
but my experience from fixing my iPhones is, that, every screw fit only in the right socket even thou they are really small, the socket is not longer than the actual length. so if you have 4 screws left and maybe two are same length, and two others are short vice, versa. then one can try to with the longest screw and where ever the socket head of the screw dont reach the bottom. then naturally a smaller screw would fit in there.. and just proceed like so until every screw seems to fit tight.. another thing you could look after, is if there seems to be more layers of different components. then most likely if there is a space where the screw is supposed to hold onto more, then it will probably be the longest left..
Happy screwing :-D
by
Add a comment
Add your answer
jasmynnsg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 2,485
