It was a six-wheeled tank with a front-mounted blue photon beam headlamp, and a keypad on top.
Why won't it go straight,turns slightly
Can you tell me how to get my big trak to go in a straight line
Add a comment
Is there any small rocks, debris etc in the tracks? Because the debris might slow down one of the tracks, therefore making the tracks unbalanced in power.
Add a comment
do both drive wheels have the rubber intact? To me it sounds like one is missing. You could also have a motor that is a little lazy or debris on the magnet clutch in the gearbox.
If the rubber “tracks” on the drive wheels are intact, I would make it run for a while with the drive wheels off the ground and make it go thru a few “forward + 99” commands, and see if the clears the clutch and gets the gearbox to move more freely Aside from that a complete teardown and cleaning of the gear box, which is very involved.
Add a comment
Add your answer
lisa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 585
