Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
471 Questions View all
Black Screen/External Monitor ONLY ON SAFE MODE
Hello,
Couple of nights ago I close the lid of my macbook and the next day I woke up to a permanent black screen.
I tried Resetting the PRAM, SMC...
I connected an external monitor and nothing happened, until booted in safe mode.
I managed to retrieve my info and boot into recovery (via external monitor) to format and re-install OSX.
Did a clean install and it still wont boot. Tried Safe mode and it worked (external monitor)
So i need your help to understand if it could be repairable or i have an expensive bookend.
Thanks !
Score 2
4 Comments
i have the same problem, did you manage to fix it?
by
I am with the same problem. I've successfully boot the machine with external monitor in safe and recovery modes.
But the laptop screen is always with black, I only can change de luminosity on it.
Please share if you manage to solve the issue. Thanks ;)
by
Hi I also have that, did you work out any solution?
by
Did anyone got the answer? I have the same issue.
by
Add a comment
1 Answer
Chosen Solution
I'm sorry I missed this post ;-{
I suspect all of you encountered a problem with the backlight power circuit. I've had a few of these come in.
To prove this is the issue you should be able to shine a flashlight into your display logo (a poor mans backlight) you should see the faint image of your desktop icons. If you do then your logic board needs repair. I would first see if you can get Apple to cover it under warranty,
If you can't get it fixed under warranty you might be able to get someone with micro soldering skills to replace the driver which is on the back side of the logic board.
Score 4
Add a comment
Add your answer
Joe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 4,347
