Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Why won't my phone turn on?
I replaced my battery and when I first put it back together it turned on, but all I saw were white lines running through the screen. I took it apart again and rechecked all the connections. I put it back together and now it won't do anything. What can I do or check?
Add a comment
Chosen Solution
Does itunes recognize the phone ? Is it possible that you may have shorted the battery while installing it .Did you get the screws back in the right holes ? Some screws are longer than others and if you put them in the wrong spot you can short the phone. they end up going through the board and touch the case. Guide may help
iPhone 5 Teardown
Score 1
Add a comment
are you sure you didn't disconnect any other connections or placed the iPhone near any magnetic item it should of been a straigh straight forward battery fix you didn't damage the battery connector
Add a comment
Add your answer
jennifer shewman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 58
