Can I Repair my Samsung T.V Myself
Vertical think Blue line running down the right side of the T.V.
@bmilleythat sounds like a failed TAB on the panel. Disassemble your TV and put some pressure on the top of the LCD where the flat ribbon cables enter the LCD. See if that changes the line. It is also possible that it is a bad T-con board issue. I'd replace that before doing anything else.
You can try unplug the lvds connector cable between the main board.
Clean it with pencil eraser until it look shiny. or you can clean it with cleaner fluids and dry it
Connect them together and test it
If it's not working then your main board is broken.
That's the simple test.
marten tulenan "then your main board is broken." how do you figure that from the OP's description? Sounds like a pretty wild guess based on a simple eraser repair.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 310
