PSP Pro Update Issue
hello, i've got psp 3004 by sony, it doesn't allow me to play games without entering pro update, when i open pro update it's just whole black.. no button works there, even removing battery only works if i want to do anything else
Add a comment
1 Answer
Try doing a system restore after backing any data up to a memory stick. Also, make sure you are connected to wifi when entering the update
1 Comment:
You don't need to be connected to wifi to use the pro updater. @Zohiab try to redownload the needed files for pro cfw then download infinity. Run pro updater and install it then run infinity to install it once then run it again and press left to select one of the two permanent firmware options.
Official Firmware (6.60/6.61)
https://darthsternie.net/psp-firmwares/
Pro Firmware Installer
https://www.gamebrew.org/wiki/PRO_Firmwa...
Infinity Installer
https://infinity.lolhax.org/
by
Add a comment
Add your answer
Zohaib will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 166
