Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Questions View all
Why my iPod not charging
Yesterday i tried to put the USB electrician on my iPod charging port and it pop up " The accessory may not be supported" and now its not charging? what can i do. Now its drained. What can i do please help me.
1 Comment:
I think the charging port is clean. When the message pop up "The accessory may not be supported" it stop working. and i turn off the iPod. It still wont charge. and then i click the home and power off button at the same time and it still doesn't work. Do you have more ideas what can i do to my iPod?
by
Add a comment
Did the charger come with the package? If so, i dont know what to do.
Get a proper charger
Add a comment
Clean ur charging port with a tooth pick. It works I had to do this on my iPhone!
1 Comment:
Its clean. But its not working. Do you have idea what can i do?
by
Add a comment
Does it make the charging sound when plugged in? If not then it's not clogged but jammed with lint! I litterly had to scoop out the lint which I could not see with a tooth pick all the way in the back not the sides.
Add a comment
Add your answer
oscarjosephdamalerio will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 719
